water in cylinders
angler0520
hey guys i have a little evinrude 15hp tiller i put a new power head on my mid section and it runs but very poor when i checked the plugs they have water on them were are the few places water could get into the cylinders?
mikesea
Re: water in cylinders
head gasket,exhust cover gasket,powerhead gasket
bktheking
Could be water or could be raw fuel, my 15 looked like water then I figured out there was a stuck open reed.
angler0520
i put this powerhead on myself i put the new base gasket on if it is leaking there how does it get into the cylinders?
bktheking
Upper water tube grommet, did you replace it?
angler0520
no i sure did not is that a seal that seals aginst the bottom of the powerhead?
bktheking
It does seal tight against the powerhead, there is a water inlet at the bottom of the powerhead, right beside the exhaust which of course leads to the bottom cylinder.
