CaptnKingfisher
- May 14, 2017
- 259
I picked up a new-to-me boat this winter. Ran around on starboard fuel tank everything was good, switched to port tank and died after about a minute. I took a sample from that tank realized it had water in it. I drained the carbs and switched back to starboard tank and was able to restart the engine and get the boat back on the trailer.
I really don't wanna hafta rebuild the carbs on this. 150 hp v6 with 3 carbs. What this can I try before rebuilding? I was think pull carb drain screws and flush carbs with fresh gas then pull out all the spark plugs and crank the engine over. Is a carb rebuild absolutely necessary when you get bad gas? Thanks
