Water in gearcase
Thuffjr
How does water get into a alpha one lower unit? Is it through the small o-ring seal or the seal on the uper section? I am asking because i need to replace my lower unit and i know the only seal there is the small o-ring but im not sure if that is where the water was getting in.
Don S
Re: Water in gearcase
The most common way is for water in the bellows because they were old and not replaced.
After that, it's any seal on the drive.
Pull the outdrive and check for water in the bellows. Then drain the gear lube and pressure/vacuum check the outdrive. With a pressure check, a spray bottle of water with some dishwashing liquid will show the leak by blowing bubbles.
bigskiohio
Master Chief Petty Officer
i had water in my oil and pressure test showed good ,i am guessing water pump but how would that show up in pressure test? a little water not alot.
achris
More fish than mountain goat
A pressure test only checks to see if oil can get out... A vacuum test is needed to see where water can get in....
Chris.........
Ayuh,... And the shift shaft seal, 'n the propshaft seal, 'n the drive shaft seals, 'n on, 'n on...
