water in lower gear oil
htg900
I have a1984 Four Winns candia 190 with a mercruiser 140. had motor swapped then when I got it back water pump in outdrive needed replaced. After replacing it I went to lake for day had little oil film in water when I got home I drained lower lube and oil was mixed with water any suggestion on where I should start to fix problem?
Re: water in lower gear oil
Ayuh,... Did you get the Quad-ring Inplace,..??
htg900
I am new to this working on boats. Could you please explain what and where the quad ring is?
ziggy
it's a small little special oring.
it goes between the upper and the lower on the starboard side. slightly fwd. of center of the drive. there's a small recess in the lower that will accept this quad ring. w/o this seal. there is no seal between the upper and lower. this is the only passage between the upper and lower. the upper and lower share gear lub through this passage..
