TillamookB2
- Aug 5, 2010
- 24
I've got a 1959 Mercury 55A. I just went out and pulled the oil drain and vent plugs on the lower unit and all that came out was a small amount of thick, greenish goop and about 1/16 cup of water.
It sat for two years before I got it. Since I had the motor, it's been in the water once to make sure it floats. I've run it a total of maybe fifteen to twenty minutes in neutral to test repairs.
I know a small amount of water in the gearcase is inevitable. Is this too much? It had already separated from the oil by the time I opened it up.
I saw no rust coloration in the water.
Do you suppose its safe to refill with fresh gear oil? Maybe fill it, run it for a few minutes, drain and refill?
