Re: water in lower unit
I changed all the fluids, did the impeller, checked the ujoints, bellows, gimbal, changed fuel filter, lubed, stabil, etc. Im not winterizing it though because it doesn't really get below 32 here. I usually take the boat out once or twice a month during the winter just to run it.
So with the water sitting in the bottom of the outdrive.. I can see the water sitting right at the level of the water inlets. If I shake the outdrive a little bit you an see the water moving back and forth in there.
Also in another post I wrote about if I leave water in the engine block after running it will leak out from the outdrive.
I have never noticed this stuff before and it might be normal but after doing work to it i haven been keeping a closer eye on it and wonder if there is something wrong. thanks
