water in oil how where ?
Alfred jobs
I have a 1991 3.0 cobra. It runs good comp is 160 +/- on all 4cyl getting water in #4 . i pumped 15psi into the head and block its still holding after 8hrs and when i crank it runs great for about 10min and then fouls the plug.Pull plug and water on #4 .Could it be the manifold or what ?
Bt Doctur
Re: water in oil how where ?
The exaust riser most likely has a hole in it, remove and inspect for holes and any wetness. that allows water to foul #4 plug.
coastalcruiser
Check out the riser Gasket! I found mine with the gasket folded over.....
lowkee
Welcome to the 'not-so-professionally-installed' club. We're growing in membership by the day.
I'm replacing my transom becasue whoever installed the transom plate bent the gasket and let water leak in.
Glad you found the problem quickly.
Alfred jobs
Hey i fogot im takeing water in the oil sorry it was late would it be the same problem again sorry for leaving this out
coastalcruiser
You have another post about your manifold needing to be replaced, if you have water in your cylinders drain the manifold-risers take the spark plugs out crank the engine, water will shoot out. I would then spray inside the holes with penetrating oil to prevent rust then replace the manifold and risers right away.
Alfred jobs
thanks for the tip i wouldn't have thought about the water in the cyl's
Bt Doctur
Did you remove the riser to check for holes yet?
The longer water stays in a engine the higher the repair bill.
Alfred jobs
Yes i took off the riser and manifold it was the manifold ,middle ex has a crack .I filled with water and leaked out in ex now i need a manifold used would be nice but new wold be better ? the castings on it are not found anywere can you all help #'s 986518 --A-- this is under the #s and a raised stamp looks like P/F or R/F in front of the #s
Alfred jobs
would this cause a lot of water in the oil ? I pumped up the block to 15psi and it held when i checked the oil its about 2qts over that sounds like a lot to me thanks
