Re: Water in Oil in outdrive
pull the prop. there are 2 oil seals on the prop shaft. sometimes fishing line gets wrapped around & ruins these seals. could be seals around water pump shaft. did u pull the drive? check mating surface gasket. how about o ring on dip stick? drain screw o ring?
