Water in oil lower Unit OMC Sterndrive
turco555
Hi, I have a OMC Sterndrive Electric Shift and when I remove the oil from the Lower Unit I detect water. I am replacing the seals and orrings. Inside it is dirty with thick oil. How do you recommend cleaning without having to remove the electromagnets? thanks
fill the drive with diesel fuel. let it sit.
then drain.
diesel fuel is a great solvent
