water in oil
jadair
1977 Galazie, pulled engine to fix flywheel. replaced everything, now there is water in the oil. possible problems besides cracked head
jadair
Re: water in oil
Sorry, 1977, 175 HP, V8 with ford 302 Probably a cracked block but was running when the starter went out and had to replace teeth on flywheel put it back together and water in oil.
Re: water in oil
Ayuh,.. You're Probably Right,...
That's also when the oil level was Rising...
