rmeredithiii
- Jul 12, 2003
- 1
I have a 1986 2550 Bayliner. I have just re-Engined it from a 225(305 Chevy) to a 280Hp (chevy 350 marine engine). With my old engine, using a 143 degree thormistat, I would start to develope signs of water in the oil when i was in cold water(less than 60)and runing for long periods in the canal (1300RPM). But would tottlely disapear at normal planning speeds. With the new engine, water shows up in the oil at any loading. It never is enough to change the oil to a milky color but in colder areas like value covers and caps the oil looks like lithium white greese. I changed the thermistat to 160 degrees but still develope tracies in the engine cooler areas. Oil appears clear and of good color though does not seem very warm (can hold end of dip stick confortly with out being burned). Valve cover vents to carb are always steaming. This is a new engine with less than 50 hours. It is a marine short block with a Edel Brock Proformer manifold and an marine EdelBrock 500CFM Proformer carburator. I am also runing a marine Prestilite HEI distributor at 8 degrees BTC. All other components are from old engine. Inclueding the 15x17 pitch prop. Engine turns up to 4500RPM.<br />Is this a normal thing, or do i need to look further. Also my friend just re-engined his boat and is have the same problem!
