water in oil
jp1222
I have a 2003 Larson with Volvo 4.3 have winterized myself for years got it out of storage checked oil had water in it. Read a forum from several years ago said intake manifold probably cracked pulled it off and no cracks.Has anyone had this problem and what was the cure?
WIMUSKY
Head gasket.......... Check the plugs and see if one looks cleaner than the rest. If so, that's the cylinder that's sucking in the water..... It will be pretty obvious what cylinder is being "washed"...... Is it hard to turn over at times, that's another indication. Tough to compress water. Things tend to bend when you do...... Like pushrods......
