OK, I think I get to wear the dunce hat now....
Maybe this post will help someone else (besides me
End of last season - the outdrive was leaking oil - didn't think much of it (but should have)
Did the usual winterization on the engine and exhaust manifold - didn't drain or re-fill the outdrive!
Last season, I replaced the outdrive oil and put too much oil in the drive - and blew out the shift lever seal and the drive shaft seal to to outdrive - unsure just yet of the propeller shaft seal. - Haven't done the pressure test on the unit yet. Will do that for sure before re-installing the drive. NO Doubt
So a comedy of errors going on here:
My question is, was there enough water in the outdrive oil to do internal damage to the outdrive over the winter?
I'm in Tulsa OK, so we don't have severely cold weather for long amounts of time, but we do see below freezing temps about a month or so - especially overnight temps.
I'm once again in the process of replacing all the seals, o-rings, gaskets, pressure testing etc etc. I know I'm trying to dodge bullets here, but I think it may be a lost cause if damage to the outdrive itself is too far gone? It doesn't have any obvious signs of bulging or cracking anywhere.
End note, we took the boat out last weekend (after replacing most the seals, gaskets and o-rings) and it performed great, no weird vibrations, but once again we have water in the drive unit (milky oil) I apparently installed the shift lever sealing ring upside down - was leaking pretty bad - I get to do all of this over again soon - Man, this is wearing me out!
