Re: water in piston
Author Topic: water in piston <br />rmel <br /> <br /> <br />My guess would be the exhaust plate gasket. If you decided to pull the exhaust plate back off, place a straight edge across it to make sure it is not warped.<br /><br />When you replaced the plate last time, did you use sealer on the gasket?<br /><br />Some posters on this site (and others) recommend using sealer, while others recommend against it.<br /><br />If the exhaust plate was not warped, I would lean towards no sealer. If it has some slight imperfections, I would consider Hi Temp RTV, on one side of the gasket only.<br /><br />Search this site for opinions, and search the Scream & Fly web site for more.<br /><br />Good Luck,<br /><br />Gold Bear
