I keep my boat up on a lift almost always. While I was on it I could hear water sloushing when I "rocked" the boat forward in backwards. It seems to be in the rear starboard side compartment. There are 4 plugs in each pontoon and I do believe they are separate. It's a 22' 1996 Crest II.
I have a plug with a stem valve that I picked up and I was going to add air and check for any leaks. I've read the info about putting too much air in them. I was going to use a prefilled air tank or maybe a 12v tire inflator. Will that work?
