I changed the gear oil in my drive and it was clean with no water or metal. After 2 trips of tubing i have had to add about 1 inch of gear fluid into the reservoir. when i changed the gear oil i used the pump from the bottom up. Now i am wondering if i have a leak. Bilge is clean,hose is dry. I did re-use the drain plug gasket and the top plug as well. Should i remove the top plug or drain plug to check for water intrusion? or is what i have experienced normal?
Dont want to drain out perfectly good gear oil that has only about 5 hours on it.
