water in the bilge
popey
Hi there
I noticed, that I have some water in the bilge. Usually this is bone dry and the sterndrive was fixed last year.
Is it possible (or known), that a waterpump leaks? (engine: Mercruiser 165 IL6)
It is a fres water cooling system.
Thanks for your answer,
popey
TiredoleBoy
Re: water in the bilge
do you have a closed system? If so a pressure test could be done to see if the water pump leaks.
I would also check the shift cable boot for a small crack.
popey
Thank you very much.
It is a fresh water cooling system.
I realised it yesterday after driving quite a bit at 2000 rpm.
Fordiesel69
Also the boot that goes from the exhaust elbow to the ypipe can rot out from the inside.
dubs283
leaks aren't specified to any one component/area on a boat, they can happen all over
to find the leak you have to get your head down in the bilge and look/listen for water dripping/running in
sometimes you won't find a leak until the engine is running
