Water in the cylinders of a Chevy 305 in a 2001 Bayliner
dziner55
The old engine in our Bayliner was getting water in the cylinders. We rebuilt the engine, changed the manifolds and the manifold "Flaps" and the gaskets. We took the boat out today and it ran great! We stopped to do some fishing and when we went to start it again, it would not start. We pulled the plugs and have water in the cylinders again! It is only in the cylinders, not in the oil. Any ideas? We thought we changed everything it could be.
Vince
alldodge
Re: Water in the cylinders of a Chevy 305 in a 2001 Bayliner
Looks like your getting water up through the exhaust. The flappers you mentioned are the ones in the Y-pipe correct?
Going from a yes on the flappers above, is the boat the kind that when fishing everyone is on the stern? If so do you think your setting so low with all gear and everyone back there that your stern sinks below the height of the risers? If so from waves and rocking you might be getting water flowing back.
Just guessing
NHGuy
The only things you didn't change could easily have been the culprit. That is your risers. Change them. Just do it. When they rust you get this exact problem.
tpenfield
Not know the details of your rebuild, but if you used the same intake manifold and cylinder heads, then start to look there for the source of the water. Maybe you could pressure test the cooling system . . .
dziner55
We are not running an antifreeze system, just bay water pumped in . Different block and heads, but same intake. We changed the manifolds. I have to see if we changed the risers as well. Does the fact that it is on all cylinders tell us anything, as opposed to it just being in one head?
tpenfield
It could point to the intake manifold . . . it is possible that the problem could be on one side, but I would be looking at the intake manifold at this point.
Since you have water in all cylinders, probably best to do a compression test to see if you have any bent connecting rods, etc.
alldodge
It happened with the first motor and again with this one. It is on both heads, I'm going with my first post
