Re: Water in the engine compartment, normal?
I'm a noob as well so I'll just tell my story and let others chime in. Until leaving Lake Mead earlier this week I had never had a drop of water drain from the engine compartment after pulling my transom plug. Tuesday, after a long day of tubing with some pretty gnarly turns, I pulled the boat off the shallow launch and up the ramp. After snapping on the transom straps I went to pull the plug. This was the first time I had to get a set of channel locks to loosen it. When I did, about 2 gallons of water came rushing out. I was heartbroken since I was convinced that I had cracked the head o hydro-locked the engine. In fact I spent the rest of my vacation just sick thinking that I ruined the boat at the start of the summer. To top it off, while we were trailering the boat, the oil alarm went off.
Took the boat out today to do a diagnostic. Launched fine after adding gear oil. Turns out the water was from the 2 large 4 person tubes that we pull where water gets caught in the jackets. When the kids pull them about they don't drain them out of the boat, they just let the water drain wherever. I call that a teachable moment.
I decided there are two things to consider. One, what were you doing on the boat? Were you running hard, turning sharp? Two, was the water draining warm, like it ran through the engine or cold like it came in from outside. It still wouldn't hurt to inspect your transom or keel for cracks or holes, especially if the boat is habitually beached. To determine if there was a leak, I had my wife drive the boat while I had the engine cover open and watched for water or oil leaks. All went well.
I sincerely hope you find that all is well and your season is a fun and adventurous one.
