Re: water in the gear case
There are double seal's, and an o-ring on the upper drive shaft bearing carrier. There is an o-ring, and gasket on the shift rod cover. There are double seal's, and a o-ring on the prop shaft bearing carrier, all of these double seal's are put in back, to back. There are four screw's that hold the prop shaft bearing carrier, these also have an o-ring under the screw head. On the double seal's, I pack the void between the seal's with grease,such as OMC triple guard. All of the above are a possible source for a leak. Having every thing clean is important. The carbon build up around the prop shaft carrier can be a problem if it snag's the o-ring. I clean this with a medium steel wool when I have the unit apart, then flush with part's cleaner, or hot soapy water.
