I am installing a water inlet tube in an Alpha one transom.
Well after 2 hours fighting with the water inlet tube I got it on the
90 degree pipe. Only problem is there is a permanent kink in the tube
around 10 Oclock. Must have screwed up the mesh inside the tube or
something.
Well here goes round 2.
Can you please provide ANY tricks you found out that would help with
this. All I have seen to date is that it is a Royal PITA.
People suggested the following:
Put the hose is boiling water. Might be hard to handle hot you would think?
Putting oil to tube and metal. Ditto.
Using a screwdriver and wedging it at 9 oclock to help leverage moving
the tube towards the 90 degree metal tube.
something.
