MichaelBC
- Feb 28, 2020
- 110
Hello,
my dry joint ellbows have two water inlets. So in one I will put in the connector for the water hose of the closed cooling to let the seawater out and the other one is pluged.
So as you can see in the picture it would make my setup a little easier to use the upper hole insted of where the connector is put in now.
So my question is if there is any reason why I should use the lower opening insted of the upper one and if there are any disadvantages if I would change that.
Thank you for your help.
Michael
Michael
