Water Leak From Exhaust Relief
atv_freak
From what I'm reading this looks like the y-pipe is cracked/has hole/bad seal? It leaks into the boat when I back the trailer in and it leaks from the boat when I fill the bilge up. 1990 Donzi DL190 with OMC 4.3L and cobra out drive.
atv_freak
Is that the transom seal or an exhaust seal? I seperated the manifolds from the y-pipe and was surprised to see the flappers were still there. I stuck the hose down the y-pipe and did not see any water leaking into the bilge, just the exhaust holes under the out drive and the exhaust bellow. That means the y-pipe is alright correct? I removed the piece of saggy gasket and ran a bead of 5200 under there, so tomorrow I'll fill the bilge up and see if there is still a leak. If this solves the leak, I realize this is just a temporary fix.
bruceb58
If it's leaking between the transom and the transom mount, you may have bigger issues. Hopefully, the transom isn't rotten.
