I have a leak coming in the boat, this happens when the trim is down only. Not when the trim is in the trailer position. If you look at the picture you can see the water coming in below the water line and dumping right on the drive shaft. It does this with or without the engine running. Where is it coming from? My best guess is the shift cable bellows.. is that correcct?
