Water leakage problem
Hello, i have a 1969 Mercury 40 Hp model 40.<br />I just corrected a cooling problem and wanted to see how it ran so i got it hooked up to water and started it in the driveway. It started on the fourth pull which was nice and in about 5 seconds i ad good cooling. So i took the cowling off to see inside and everything seemed to be in good working order. But i went to look at the back and ui saw water bubling around the plug. (This is a 1 Cyl. model.) I realy didnt know why this is happening. Im not sure if its a cracked block or just a gasket problem. There is a platearond the cylender where the cooling water goes through and i took that off and it looked ok and the big gasket looked ok but it was a little melted so maybe it needs to be replaced. If anyone could help me out that would be great Thanks!!
The Marine Doctor
Re: Water leakage problem
The gasket you refer to is to seal the water jacket cover.<br /><br />Replace the gasket, seal around the hole with a known good sealer<----Do not believe that the grey stuff that Mercury has on the gasket will seal...it does not, then reinstall.<br /><br />TMD
thanks i will start looking for a gasket today.<br />Also i am not sure the year what would My motor be Its a 4 Hp model 40 s/n 3938502 Thanks
