I have a 1976 Mercury 85 hp outboard that has water leaking from around one of the spark plugs. I looked through past posts and suspect that it may be a gasket problem...I sure hope so anyway. I'd like to get some opinions about whether this is the likely problem and about just how involved it would be to repair. I am fairly good with making mechanical repairs if someone can lead me in the right direction. I have rebuilt the carbs, replaced the water pump impeller, and replaced the shift/throttle cables on this engine. Would this repair be similar in difficulty level? I have a Clymer shop manual that covers this engine, but doesn't give any troubleshooting information on this specific type problem. Thanks for any help/advice you can give.<br /><br />Mike Hannah
