bass4brains
- Apr 2, 2007
- 29
Just pulled lower unit on my 50hp. force blocked off exaust ports at the bottom and on leg, leaving only peee hose open. Under pressure I have water seeping from around spark plug inserts as well as out of the vent hole in the cover behind the main terminal block on the side of the engine. There's no water in cylinders and both plugs are nice and brown, but will only run in lower three tilt slots if raised to the top two it'll run hot. I'm begining to feel cracked power head as well as crancked or warped cylinder head somebody say it ain't so Please! Ijust bought this boat end of feb. and had problems ever since. Just call me bumfuzzeled!
