Hi all, I'm new here and thanks for all the great info!! My problem is, I have a 1984 Evinrude VRO 90, When winterizing, I found milky oil in the lower unit so I have a water leek to find. I did notice that the pitot nipple on the engine (I don't use it) is loose and stuck on with some silicone and when I run the engine on muffs, water squirts out of the pitot hole. Is there any chance that water could be getting into the lower unit through that hole? Should I just pull the loose nipple out and fill the hole with more silicone? Thanks for all your help!! Kevin
