HY GUYS I have another 170 problem!
Here is the problem the coolent level in the resavior tank seems to be droping slowly down to empty in about 1 week after filling it. I checked the compresion and all cylinders are about 145 psi with no water in the oil or oil in the water. could my pro blem be the heat exchanger. I also repaced the exaust riser elbo. The motor is a 1986 170 hp with alfa 1 drive. aLso I should tell you that there is no visable signs of leaks on or around the engine block.
