Water level in cowling on 120 Force Motor
Horace Hoobler
At full throtal the motor will lose power and when I removed the cover there is water spots all over the carborator and some water in carborator cups. I have watch excelloration with cover off and water rises up to the bottom of the cowling. dealer response. "Run boat in test tank and water in lower cowling is normal. Ran up rpms and level not rising. Water level cannot rise to the carb. level unless water level outside motor is also that high which would put it above the transom." The water was not in the transom.
Fouled Plug
Ensign
Re: Water level in cowling on 120 Force Motor
Water in the lower cowling? Yikes! Sounds like the motor is mounted too low. I'm sure it's not a problem on the test tank, but on the water the boat will have some motion and could very well draw water into the carbs.
Does this guy sell submarines? :D
JB
Movng to Force Troubles.
