turbocorrado
- Aug 14, 2013
- 251
so my boat has a 4.3 with a closed cooling system, i removed the outdrive to do bellows and a reseal, when i removed the water line it was kinked and just shoved in at a weird angle.
i bought a new line, and went to install it today, but when i cleaned out the hole i discovered its capped.......so does this mean my impeller does nothing and i should just cap off the hose running out of the outdrive? there is a fresh water pump on the engine with a hose running up off the floor into the pump, and then a hose running out of the pump to the back of the motor
