ROCKMONSTER
- May 18, 2011
- 8
Hello I am new to the forums, new to boating in general, i have a 1977 Evinrude 75 serial num 75743s . Engine runs great on muffs or on start up at lake, boat will come to wot, n plane out nice for min or 2 then sputters n loses power, If i idle down seems come out of it some but wont run same after, Had a mechanic friend come over n clean all 3 carbs, all were nice adjusted all 3 floats as they were all not flat as should be.. Moved on to check compression, top cyl -150 mid cyl-140
bottom cyl -150, on checking compression he noticed water on plugs n said well there is problem, bad head gasket.. Looking for any other input as to what could be causing the issue, any input n suggestions greatly appreciated..
Rocky
Rocky
