Hello, Back again
, Ok, we're the ones with the 1977 Johnson 85HP money pit. We replaced both heads/gaskets/plugs/rectifier/water pump/impeller/fuel pump/ignition coils/fuel line and primer bulb/correct water hoses and she came with a almost new starter and carb. We posted a few days ago about an intermittent start problem and we think we have that solved after cleaning the power pack terminals. She fires every time. Now.... We went out and fired her up tonight and water is coming from only one tell-tale AND is "flushing" out between the exhaust housing on one side. My guess is the tubes somehow came loose bewteen the water pump and copper tubing. This didn't happen before. Hubby thinks we have to pull the power head. Please help !! Thank You All for your past suggestions!
