I have been de winterizing my 1986 fabuglass with a 4.3 omc cobra ? is where should water come out when running with muffs?
I am not doing something right all i need is to know how to post in the right zone i went to the lake and put the boat in would not shift forward or backwards after all simple stuff i dropped lower unit and it checked out then the upper. I found the shift mechinisim that controls the lower unit shift shaft broken it has an o ring and slides into where the shift cable attaches , with a bolt to keep it in place problem is I cant find a part number or availability anywhere i found picture but no index number or name for part can someone tell me what i am looking for ? and a source to get it? I a boat novice but not totally stupid thanks in advance slinet Lima Ohio
