water pressure and motor temp gauges
dhughes49
just bought a 2002 merc 150 hp saltwater on a kenner boat. I want to add water pressure gauge and a motor temp gauge. I don't know which one to buy or how to install them . I/m sure capable of nstalling them just cant find any instructions or videos or anything. Can any one point me in the right direction?
Yesterday
Re: water pressure and motor temp gauges
Ive seen plenty of threads on this forum and others discussing that. All point to the usefulness of a water pressure gauge and not so much for the temp, but those were for non-thermostatted Mercs. I'm not sure if yours is or isn't one.
A couple of related posts:
150 Mercury OB overtemp alarm
Engine Temperature Gauge v. Engine Water Pressure Gauge; Difficulty of Installation - Moderated Discussion Areas
Also, manufacturers of gauges often have instructions on their web sites. have you checked farina's or teleflex's www sites?
Chris1956
The pressure gauge will need to be plumbed to the cooling system of the V6. Some years have extra threaded pipe plugs you can use. Other years need to be "tee-d" into one of the water hoses. On my '93 V6, I tee-d the pressure gauge into a hose from the top of the powerhead to the bottom of the powerhead. It works well.
BTW - it will only show 7PSI at crusing speed, unless you have some different kind of waterpump, than I.
Some Mercs have a temp gauge sender in one head, as well as a overheat sensor in the other head. See what you have....
dhughes49
EFI or carb?
Its a carb motor. I have a oem servive manual on the way to help me be more familiar with the motor . I just bought the boat a few days ago.
