water psi gauge on 84 150 blackmax
crazyhunter
hey guy just wondering if i can put a water pressure gauge on my 150 blackmax. i have had some problems with my waterpump in the past and would like to be able to keep an eye on how good it is pumping. this motor has never had a pressure gauge as far as i know so i will need to put a sensor on it some where but idk where it is suppose to go or if this motor can even have one. any info is appreciated.
Dukedog
Re: water psi gauge on 84 150 blackmax
There is a large "pipe plug" on top of tha motor right behind tha flywheel. You will need ta make a trip ta your local "Ace" hardware or wherever for fittings to go there. Tha fittings will need ta adapt from that size ta fit tha hose included in your water pressure gauge kit................
crazyhunter
i found the plug thanks for the reply i will be ordering a gauge soon
