Water Pump connections
Hambone9999
The clear connection fitting was loose so I pushed it back in but how do I tighten these fittings? Is it normal for the pump to kind of make a stuttering noise when running (only when I turn the tap on).
they are push-to-connect fittings
and yes, the pump will hammer a bit at low flow as it is building pressure, and being turned off by the pressure switch, then loosing pressure because you have the sink running
turn the faucet/tap on full and the pump just runs.
