water pump counterclockwise
Frankiea87
hey im installing the water pump and manual online says counterclockwise.... but i would assume thats on the boat? look at my pic that would be counterclockwise while holding it in my hand... but when installed right side up.. thats clockwise?
Don S
Re: water pump counterclockwise
Not sure which "Online" manual you are talking about, but the OEM manual up in the Adults Only sticky says you turn the vertical shaft clockwise while pushing the housing down over the impeller.
