Water pump dripping 5.0 GL
Laneman25
I think its the water pump, hard to tell. All hoses are tight. Anyway, it's about 1 drop per second. Can I run it once this weekend, or is this a high risk?
Which pump? Raw water or circulation pump?
Laneman25
Can't tell where it's coming ftom. Drips on belts. I found an old thread about this issue and changing a shaft seal. Fresh water use only, carb engine.
If it's the circulation pump (bolted to block) then replace before use. Dripping means the thing is soon to fail
If it's the raw water pump (bolted to crank) then that one is easily rebuilt, and you can probably use it this weekend, however should repair or replace soon
Laneman25
Thank you Scott. I'll try to get a better look. I think it's the raw water pump. It's splashing off the belts
Scott06
Probably ok to use just keep an eye on it. How far from the ramp or where you keep it are you going?
Donald0039
Water pumps are made to weep before they fail. If it's not a hose with a leak then replace the water pump. It will get worse.
