johnnyxxxx
- Jun 12, 2003
- 7
i changed my water pump! the motor is a 1973 evinrude, when i took the pump housing off i noticed ,that the old pump looked new, nothing wrong with it ok. however, why i changed it is there are no water coming out of the holes. enyway, i hooked a water hose to the tube going up inside the motor, i found that the tube is busted,i need to change the tube, but i can not get it out... how do i get the little tube that carries the water to the motor????
