water pump: hole question
mark abby
new water pump and i noticed the new (and old) have a hole back by the water tube inlet.
can any one tell me why they have this hole there? it goes thru both housings and i never saw any gaskets for it when i removed the old pump. what function does it do?
see attached.
Laddies
Banned
Re: water pump: hole question
There should be a either a 1/4" s/s bolt or a 1/4" s/s self tapping screw in the hole to help seal the 2 housing together.
mark abby
thanks.
that's interesting because there was never anything there when i removed the old pump...which could be why the bearing failed on the driveshaft. maybe it allowed water to leak down onto the bearing (?)
Faztbullet
It missing did not cause bearing to fail.........
