Re: Water Pump Housing
Thanks for your replies! Replaced the housing, the stainless cup the impeller sets in, impeller, and gaskets. Started motor and it spits water nicely from the idle relief holes. What I noticed after shuting it down was gas coming out of the lower carb a drop here and there but enough to pool in the plastic carb cover. Is this normal? As for the thermostat replacement, the one I bought through iboats mega mall was too small. It would go right into the water jacket. Tested the old one and it tested good, so I put it back in. I then went to a NAPA store and found out there that the larger thermostat is a Chrysler stat, which is still available thru them only its 143 degrees instead of 130 degrees. Splash down is up next. Thanks Bill Mc I should add that when the gas was dripping the motor was tilted up.
