Water pump housing
Mi_fiveo
Pulled my water pump housing to replace my impeller. Noticed some wear grooves in the housing. Should I replace it or leave it alone?
GA_Boater
Chances are that a new impeller will be messed up if you re-use the housing. I would replace it.
How is the wear plate the other end that the impeller also rides on?
Mi_fiveo
deda0a55-9365-44a0-87b6-f0f1f43a13f4
Mi_fiveo
Looks like it’s groved too.
GA_Boater
The plate is just as bad. A compete kit is the way to go so the impeller lasts.
