Water pump impeller blades 1960 Interceptor
Glasply
I’ve got a 1959-1960 interceptor FE block inboard in a century resorter. The water pump uses a fixed bronze hub with two sets of impeller blades, each about an inch and an eighth square, that slide into the hub, and between the sets is a retainer clip. There’s evidence of some gasket-tack type glue in the hub and some on the impeller blades.
The blades themselves are symmetrical, with rounded ends that ride in the hub or form the wear layer against the outside of the pump. Any idea where a guy could source some of the rubber used for these blades?
Thanks
Glasply
Thanks
alldodge
Have you thought about replacing it with a newer one?
Sherwood pump M10280G for RH or M10270G for LH
jwood222
Not sure if you are still looking, but here is the info on that pump, its a sherwood L9870G, and the part you need to replace the veins is Sherwood Impeller Blade Assembly 09745.
