I am changing out the impeller on a 1981 Rude 150. The impeller that was originally installed had a round pin to lock it to the driveshaft. My replacement kit has a wedge type insert but a keyway on the impeller. Question is: Can I use a standard key to match the new impeller or should I get an impeller to match the wedge type insert? There is no keyway on the driveshaft, just a flat.<br />Thanks<br />Rob
