Water pump impellor R@R
PierBridge
How much would a waterpump r@r be for a 1982 115 Mercury. and what does the job entail... :p
Clams Canino
Re: Water pump impellor R@R
part $24<br /><br />Labor 1hr tops - including changing gear oil.<br /><br />-W
rodbolt
for about 35 dollars you can buy the entire upper housing kit. it takes an hour or so to install if the fasteners are not corroded. longest I spent was 6 hours but i had a bit of trouble convincing the studs to come out of the housing:) :) . salt bites.<br /> good luck and keep posting
Clams Canino
Ever have to cut the impeller off the shaft with a hacksaw because the brass married the driveshaft? That's almost as fun. :)
<br /><br />Originally posted by rodbolt:<br /> longest I spent was 6 hours but i had a bit of trouble convincing the studs to come out of the housing:) :) . salt bites.<br /> good luck and keep posting
rodbolt
hahahah cutting impellers is among the favorites of the OMC techs :) :) <br /> gotta love the nylon hubbed ones:)<br /> good luck and keep it cool
