water pump indicator
hank56
I recently lost the threaded water pump indicator (tell tale) for my 90HP 2002 Evinrude. I can't seem to find a store that sells them online. Does anyone know of anyplace that sells this part?
thanks
Vic.S
Re: water pump indicator
If you can locate the part on the diagrams at Shop.evinrude and it is available you should be able to order it direct. Alternatively they'll give you the part number and enable you to order it from a dealer of your choice.
Clicking on the part number will open a window that lists equivalent parts
