Hi.
Ive been given a merc 1000 /100hp 6cyl which i believe is a 1964 model (sn 166943)
I was given it because the guy had been trying for over a year to get it going and couldn't and said he thinks its a wiring issue,
Well 2 days later i get it going, turns out the wiring from the control box to motor was corroded all the way through.
Is there a place i can buy the plug from that plugs to the motor so i can wire up my own as they sell tinned cable here.
But this question is about the water flow.
I started it and it ran ok with the hose on, water came out the prop and out the vent at a splutter at the front.
I did see a small hold from the exhaust vblock that comes out the cowling and figured this is the water jet (thats on most engines to show pump is working)
This wasn't producing any water at all so i put the leg in a big container of water to see if it worked and it still didnt.
Does anyone know if that is supposed to be a water jet there or if what ive said about where the water comes out from is ok?
also how do i remove the gearbox as i might just replace the impellor anyway.
Thanks all
Thanks all
