I recently replaced the water pump on my alpha1 gen 1 drive. I watched a bunch of videos while doing it and noticed that when I run mine on the muffs that I don't have nearly as much water coming out the prop as others. When I run it I get a little spray out of the exhaust prop, and then a bunch sprays out from the sides of the drive. Since I replaced the pump my temps have been lower 140-160 while on the water. before the replacement it was 160-180. Should I be concerned that there isn't much water coming out the prop while on the muffs? thanks.
