Boater1010
- Sep 24, 2009
- 53
I have a 1976 Johsnon 15hp that I just installed a new water pump kit in. When I went to start it it seems to pump water fine through the exhaust hole, but It was also squirting water where the shift rod goes through a rubber gromlet in between the lower unit and upper. Could anyone tell me if this is normal and if it is alright to leave it this way? i did check the lower unit and cleaned the cavitys as well as i could.
Any help appreciated
Thanks
Chris
Thanks
Chris
